Forum: Music discussion
Topic: Looping Mapper Question
AJMicalPRO InfinityMember since 2010
Is there a way to set a loop, and when you exit - the track picks up as if it were running the whole time?
What i have been doing which kinda sucks is exiting the loop and seeking +4 at the same time, but there has to be a better way.....advice?
geposted Sat 23 Jan 10 @ 11:36 am
Do you use smart loop? It is a little lock icon near the loop buttons in the skin. Try turning it on (icon changes color) and see if that works for you. When I exit a loop with this feature on, the track just continues on from where I turned off the loop.
geposted Sun 24 Jan 10 @ 7:26 pm
I understand what you mean, but there is no way to map it like that, however, I do something similar to this using the beat box "effect"
Try that and it shounld do what you want to do.
geposted Tue 23 Feb 10 @ 12:11 am
