I have noticed that when using the Text 2D plugin with the 12 hour clock function, their is a glitch. Even with the seconds box unchecked, for the first 10 min. after the top of the hour it still displays the seconds. As soon as the clock goes past XX.09:59 the seconds dissappear and the clock goes back to normal displaying only the hour and min.
Doesn't seem to be a problem with the 24 hour clock.
Problem is that I want to have the time overlay a box graphic and fit inside it centered. Impossible to do when the size of the clock keeps changing with the addition of seconds for 10 min. every hour.
Any one have a solution?
DJ James
DJ James
geposted Sat 23 Jan 10 @ 4:18 pm
I can't reproduce it here. Can you give the full hour. Was it AM or PM ? ...
geposted Sun 24 Jan 10 @ 10:04 am
It was PM. Not sure if it also does it during the AM hours or not.
DJ James
DJ James
geposted Sun 24 Jan 10 @ 1:57 pm
I (kinda) noticed the same. I used it for the first time during New Years Eve..
I started with the seconds unchecked, and at one point the "seconds" came on , on their own??
Ended up shutting it down, then re-engaging, this time running with the seconds on.. (I dont think their was a problem after that.)
geposted Mon 25 Jan 10 @ 2:08 pm
