Has anyone played with the gater effect in Traktor Pro?
If you havent its awesome...
Is this available as a Virtual DJ plugin?
geposted Sat 23 Jan 10 @ 7:30 pm
Im guessing thats a no then...
This forum sucks
This forum sucks
geposted Mon 25 Jan 10 @ 1:12 pm
VDJ can use VSTs, and a whole bunch of effects are available for download. You could browse them yourself to see if a plugin is available, or you could search for a VST that does the effect you want.
geposted Mon 25 Jan 10 @ 1:44 pm
Thanks for the info!
geposted Tue 26 Jan 10 @ 5:31 am
I'm trying to find a gating vst effect equivalent to Traktors gator. Has anyone found it? Links?
Tex's gates effect doesnt seem to work very well? It sounds airy and doesnt actually manipulate the sound....
geposted Tue 01 Mar 11 @ 2:58 pm
I still have to fix some things with it ;-) I planned to do that this month.
geposted Wed 02 Mar 11 @ 8:18 am
good stuff tex, look 4ward 2 seeing it. Just a suggestion.. Pls try keep the variations 2 a minimum. Wen controlling more than 2 sliders or parameters it not ideal especially wen midi mapping
geposted Fri 04 Mar 11 @ 5:35 pm
I always keep that in mind ;-) If you look carefully, in my latest plugins I always map the most important parameters to the first 2/3 sliders, while the other ones are for advanced settings. If this isn't enough, I can make a simplified version, as I did with my Filters.
geposted Sat 05 Mar 11 @ 6:02 am
Choices are always good ;-)
Huey
Huey
geposted Sat 05 Mar 11 @ 8:23 am
