is there a way to use virtual dj having no decks or mixer but still being able use headphones to cue a track in and speakers
i have configured this in setting but it does not work
i want to be able play what i want out loud and cue a track in though speakers.
sorry if i am not explaining this well
is there a way if so please explain how
thanks
thanks
geposted Tue 26 Jan 10 @ 10:30 am
Yes, a sound card like the DJIO will work fine (their are many options like this out there)
https://virtualdj.com/images/products/djio_big.jpg
You also might want to look at the all-in-one solutions like the RMX
https://virtualdj.com/buy/pay.html?buy=hardware&hardwareID=RMX
geposted Tue 26 Jan 10 @ 10:49 am
someone just showed me how to do this.
you might have 3 connections at the back of your computer.
red green and blue or black plug your headphones into the rear port. and your speakers into the others and you should be away.
if you dont have that then you could take a look buying this.
http://www.amazon.co.uk/Lab-Channels-5-1-Sound-Card/dp/B000XQ0UT2/ref=sr_1_4?ie=UTF8&s=electronics&qid=1264549448&sr=8-4
only a cheap one so you might not get the best sound quality. but its good if your just starting.
geposted Tue 26 Jan 10 @ 5:45 pm
