What is the right setup for my RMX mixer using VDJ 6 (demo)? I just can't get it to work right, it works fine with the included VDJ LE 5 version, but it just puts the sound straight out when using the pro version, none of the bottons on the console funtion. I tried every possible sound setup combination. I downloded the later Hercules Driver, updated the internal sound card and nothing. I am using Win 7 toshiba laptop with Realteck sound card, Core 2 Duo, 3GB ram. I was thinking about upgrading to the Pro version but there's no need if I can't get it to work. Tks.
geposted Tue 26 Jan 10 @ 6:20 pm
For Sound Setup, configure as follow:
- Input : None
- Output(s): Headphone > Master Chan1/2 / headphone Chan3/4
-Soundcard: DJ Console Rmx
As for using the Rmx as a controller, it should automatically be detected and listed as such in the MAPPER tab of the configuration menu.
- Input : None
geposted Wed 27 Jan 10 @ 6:48 am
Please ensure that you have the latest firmware and drivers for the console installed - A link to download can be found on the following page:
https://virtualdj.com/wiki/Common_Device_Drivers.html
geposted Wed 27 Jan 10 @ 12:03 pm
Thanks I will try that, I also get a DirecX error and a Asio Driver error.
geposted Wed 27 Jan 10 @ 3:12 pm
The error says "error in sound driver of directX"
geposted Wed 27 Jan 10 @ 5:00 pm
I found with my RMX that setting it up this way works:
Inputs: None
Outputs: Headphones
Sound card: 4.1 card
Then in the drop down menus: Master: Front output / Headphones: Rear Output
In the second drop down make sure that your Hercules RMX is selected instead of your built in PC card. I am running WinXP Pro and found that this way ran a bit smoother and was less likely to lag and stutter; using the RMX as an ASIO sound card seemed to create more problems for some reason, which seems counter intuitive but whatever works...
Your controller should be plug and play; I've talked to friends who've had issues getting VDJ 6 up and running with certain controllers on Win7; probably a firmware issue like was mentioned before. I haven't tried Win7 yet so I have no expertise there :( What version are you using in the demo? Because I found that when VDJ 6.0 came out the RMX had no buttons mapped and I had to start from scratch. Then a couple revisions later 6.0.x came out and they suddenly worked again.
Good luck!
Inputs: None
Outputs: Headphones
Good luck!
geposted Fri 29 Jan 10 @ 12:02 am
It should makes no difference if you select "4.1" or "Rmx" as soundcard. If you check the box APPLY EQ ON INTPUT, the Rmx will then switch to ASIO mode. The error will occur if your last configuration was different. Never mind it, Simply configure it again .
As for using ASIO, it's a type of driver that was developed to obtain better results with music applications, so it is preferable to WDM which is the standard for basic WIndows applications. However, you need to configure the ASIO driver so it will perform correctly with your computer.
For example,before launching VDJ, in the Rmx Control Panel, switch to ASIO audio mode, and in the ASIO tab, and set the ASIO BUFFER SIZE to 480 (10 ms). This is a good average for most computer.
Launch VDJ and use it (in ASIO mode ) for a while.Then, raise or lower the ASIO Buffer Size until you find the correct setting for your computer (there are no "ideal" since no computer are alike).
geposted Fri 29 Jan 10 @ 7:31 am
I'm having a similar problem. When I adjust my buffer to 10ms then launch vdj version 6 I get stuttering playback only when using turntables, and my asio adjustments are all grey'd out cant adjust anymore unless I close vdj. Getting frustrated. Can anyone help.
geposted Fri 23 Apr 10 @ 1:56 pm
@ Major White
This is perfectly normal. The ASIO settings needs to be configured before launching VDJ.
You will need to lower or rise the buffer size a bit until you find the setting that works best for your computer when using timecode. As I said previously, there are no ideals.
geposted Fri 23 Apr 10 @ 2:52 pm
I have tried 4ms all the way to 21ms, still stuttering but not as bad at 4ms. It actually played almost perfect for about 1 minute then got really bad again. can anyone tell me how my performance tab should be configured in vdj.
geposted Tue 27 Apr 10 @ 11:43 am
This guide might help:
http://ts.hercules.com/faqs/eng/her_eng_00364.pdf
geposted Tue 27 Apr 10 @ 12:13 pm
can some one help me please i just got the hercules rmx and i have tried everything to make it work properly with my virtual dj 6 pro but cant get it working. It works great with the disc that came with it basic virtual dj. now i cant make it play by adjusting the settings to inputs=none, output= headphones master left/ headphone right, sound card =4.1 =speakers hercule rmx but the rmx console does nothing like if music play thru it... help help please
geposted Wed 15 Dec 10 @ 10:46 pm
@ DJ Surge17
Could you be a little clearer about exactly what doesn't work ?
When using the audio configuration mentioned previously:
- Input : None
Are your speakers and headphone connected to the Rmx?
BTW, you should add your VDJ serial number in you profile. This would allow you to obtain the latest update..
- Input : None
geposted Thu 16 Dec 10 @ 6:39 am
