I would really like to see a TCCD video. I need to see if TCCD really works.
geposted Sat 14 May 05 @ 3:16 pm
lack1 --
The TCCDs work. I have used both TCVs and TCCDs. The biggest thing about both is understanding the concept of correctly configuring the TimeCode to work optimally with your system. It is not like a simple plug-n-play device, it takes some fine tuning becasue everyone's systems are different and unique.
Why do you need a video? What would it prove? What would you want to see? Also, unlike the TCVs, the functionalities of what could be done with TCCDs would be the limitations of the CD Players playing the TCCD. If you read through the forums you will see that depending on who's post you read they all have different capabilities do to their different CD Players.
cstoll
cstoll
geposted Sat 14 May 05 @ 3:27 pm
