I notice that when I run VDJ v6.0.5 the CPU usage bar is maxed and it causes video to run choppy. Does anyone know if there is anything I can do to get VDJ to run smoother?
My computer stats:
Windows XP SP3
Toshiba Satellite 1.60GHz Pentium Processor
2 GB RAM
Stock Video Card (Intel® Graphics Media Accelerator 900, 10-128MB Internal
(UMA) shared video memory)
Thanks for your thoughts!
DJ Greg
My computer stats:
Windows XP SP3
2 GB RAM
DJ Greg
geposted Sun 31 Jan 10 @ 3:41 pm
Have you resized or maximised the skin? This can lead to increased CPU usage on some systems depending on your graphic card's capabilities.
Rather than resizing, it's better to use another skin that matches your screen's native resolution. There are lots to choose from: https://virtualdj.com/addons/skins.html
geposted Sun 31 Jan 10 @ 4:34 pm
Basically (I think?) your laptop is under spec for running videos.
The recommended configuration to mix video is:
Dual Core 2 GhZ CPU
ATI or nVidia video card w/256Mb of Dedicated DDR3 memory (dual output capable)
2048 MB RAM
Dual Core 2 GhZ CPU
2048 MB RAM
geposted Sun 31 Jan 10 @ 7:24 pm
Greg, you have about the same I do with my dell. Until my crash, I had no problems whatsoever. I just rebuilt and am ready to try again. I always have a backup though because I know I'm working the thing. I'm only running 1.5 ram. I had questions on another forum regarding tweaks for xp. Maybe check it out and see if it helps.
geposted Mon 01 Feb 10 @ 4:11 pm
Have you downloaded the latest version of Direct x 9.0c?
http://www.microsoft.com/windows/directx/default.aspx?url=/windows/directx/downloads/default.htm
Also, here is a link for a bunch of tweaks that you may never have thought of. Follow ALL of them.
http://ts.hercules.com/faqs/eng/her_eng_00364.pdf
In addition, the link below will help remove bloatware that runs unnecessarily on your computer. You will need to copy and paste into your browser...
http://www.pcworld.com/downloads/file/fid,67264-order,1-page,1/description.html
Good luck!
Good luck!
geposted Mon 01 Feb 10 @ 9:36 pm
i'm having the same problem. also with a toshiba. i believe it is with the graphix card, but not 100% sure. so if any one figures this out, let me know.
geposted Tue 02 Feb 10 @ 7:01 pm
I just changed my new (glitchy) Laptops setting to the ones in the "her_eng" link and it is working perfectly!!! NO GLITCHES... HORRAY!!!
Lets hope it stays that way...
Love to the Link sender.
XXX
XXX
geposted Sun 14 Mar 10 @ 6:46 pm
