i have the denon hd2500 and i cant figure out how how do u turn the lights on. any help????
geposted Mon 01 Feb 10 @ 2:42 pm
Which version of VirtualDJ are you using? It is natively supported in the latest versions. However, the display screen in the middle will not function though (This does not support MIDI.)
Do you have the latest firmware installed from http://www.denondj.com ?
Which version of MacOS are you using? MacOS 10.5.7 had a major bug with MIDI that prevented output (LED's, etc.) from working. If you are running this version, please update to 10.5.8
geposted Tue 02 Feb 10 @ 12:18 pm
6.0.05 virtual dj
and i have the new firmware software for my hd 2500
geposted Thu 04 Feb 10 @ 3:47 pm
my mac is 10.6.2
geposted Thu 04 Feb 10 @ 3:48 pm
go to denons web site..download the latest firmware for your denon...put on a thumb drive and update acording to the directions denon provides
geposted Sun 28 Feb 10 @ 4:03 pm
also try the code from one of the other denon mappers...
geposted Sun 28 Feb 10 @ 4:06 pm
I also have no Lights displayed Running Mac VDJ 6.0.8 Denon HD2500(with latest firmware) Mac OS 6.0.3. Everything Lights up and works with a PC but not MAC. So this seems like a software issue not anything to do with the Hardware as everything Lights up and works on PC. Mac's Jog has such a better responce then PC. Well I have had a ticket opened with VDJ now for over 1YR with no resolution........
geposted Sat 24 Apr 10 @ 2:04 pm
With all due respect CSTOLL. It has been over 1yr since I have had a ticket opened with VDJ. Q to ask your DEV team is why does VDJ 6.08 work with the HD2500 Led's and all Windows 7. and MAC OSX does NOT. I am not a PC fan plus we purchased over 6 macs for the business.
geposted Thu 29 Apr 10 @ 2:54 pm
Weill im having the same problem. Using VDJ 6 with my MBP and Denon 2500. None of the lights on the 2500 work. A friend of mine uses Version 5 of VDJ with MBP and his lights work fine. Not sure why in Version 6 they dont. Any suggestions or answers???
geposted Fri 21 May 10 @ 4:39 pm
Works with PC but not MAC OSX! this is not a hardware issue this is a software issue. VDJ needs to get the DEV TEAM ON IT!. PC WORKS MAC Does Not!
Mark
Mark
geposted Fri 21 May 10 @ 5:42 pm
Actually just solved the whole HD2500 LED issue -
https://virtualdj.com/addons/11505/Denon_HD2500.html
Someone actually said something in another post that made me look a bit different at things ...
Tested and works .... :)
geposted Sat 22 May 10 @ 7:56 pm
Way to go VDJ!!!! YOU GOT THE PATCH OUT! Sorry for all my complaining but as an IT Engineer I knew this was a software issue!!!! Thanks Cstoll for this update.
Mark
Mark
geposted Sun 23 May 10 @ 12:55 pm
is this a patch to get the denon 4500's lights and everything working?? ive just today upgraded to a mac and thats one thing that isnt working, along withe the database but im trying to sort that, if theres a link for the update could you send me it please, thank-you muchly
geposted Tue 24 Aug 10 @ 5:08 am
No, it is an update for the DN-HD2500 only, which is a different controller.
Make sure that you have the latest firmware for the HC4500 installed from http://www.denondj.com and the latest VirtualDJ Pro from https://virtualdj.com/download/updates.html
If you are running MacOS 10.5.7, update your operating system to the latest version.
geposted Tue 24 Aug 10 @ 9:29 am
The HC-4500 works perfectly on Snow Leopard with the latest version of VDJ.
Keith
Keith
geposted Tue 24 Aug 10 @ 11:00 am
cheers for the quick response guys, i have latest drivers for windows etc but mac being alien territory to me im not really sure whats what, but i will get new os for mac and try that, in the mean time will work away with windows as its been faultless for me from the off
geposted Tue 24 Aug 10 @ 1:47 pm
oh yes and ive got the database sorted just copied some tunes onto a mac formatted hd and its all working so thats that bit sorted thanx again
geposted Tue 24 Aug 10 @ 1:50 pm
