Forum: Old versions
Topic: Hercules Steel DJ Controller Sound Card Help!!!!!!
Hey Everyone,
Im running into a bind and need some help. I did some searching around and still couldnt find a solution. I have M-Audio fast track ultra USB audio interface and im wondering, I havent tried it due to i dont have my steel yet, its in the mail. Is it possiable to use that as my soundcard to dj with, I also use it with my recording on pro tools. I have inputs and outputs avaible but will it work like a full fledge dj soundcard?? Any information would help. I dont want to purchase the Dee Jay Trim if i dont have to. Thanks to whoever drops some info. Thanks.
Demetrios
geposted Wed 03 Feb 10 @ 2:37 pm
Looks to be a pretty flexible card. I don't see no reason why it wouldn't work.
You will probably have to tweak things a bit around in the control panel ( to map the headphone to the right ouputs), but that is miner stuff.
Why don't you give the demo a try and look at the soundcard configuration?
https://virtualdj.com/download/trial.html
Let us knwo if you run into trouble.
