hey whats up guys so i posted b4 and i didn't get the answer i was looking for, however i have resolve my problem turns out that NUMARK CUE does not have native support for HER RMX controller instead you get a simple midi wrapper... basically you have to map it yourself and well tho i am experience in DJing lol i am having a hard time tryna map out my hercules rmx i can only getit to play and pause but the order is all screw up and i cant get the crossfader to work correctly. so i WAS Wondering if i can get a package or link of the rmx alredy mapped???? with the most recent version of cue which is cue 6. also if anybody would recommend a good controller that is native to cue so i dont have to worry about mapping it? and only if it already has a build in sound card like the rmx
THANK YOU
THANK YOU
geposted Fri 05 Feb 10 @ 11:12 am
The latest version of Cue should have support for the RMX.
Please ensure that you have the latest DJ Console drivers and firmware installed, otherwise it will not function.
A link to download can be found on the following page: https://virtualdj.com/wiki/Common_Device_Drivers.html
You can download the latest Numark Cue from the Download Center: https://virtualdj.com/download/updates.html
geposted Fri 05 Feb 10 @ 12:34 pm
sorry but cue does not support rmx you need to do it manually, however thanks to your post i realize i am entitle for an upgrade to VDJ pro from my herc vdj version for only 50 bux..... so i think i will just get the upgrade inorder to have support for the rmx controller.... thank you for your help!!!!
geposted Fri 05 Feb 10 @ 7:50 pm
i have numark cue 6 too but i want the hercules rmx. if i buy it, how do i upgrade the virtualDJ djc edition to virtualDJ PRO?
geposted Sun 14 Feb 10 @ 5:59 pm
Actually the upgrade is FROM $50 depending on what product you own, however the good news is you have Numark VirtualVinyl, so the upgrade from that will only cost you $49.
NOTE: Please go to https://virtualdj.com/buy/ and enter your VirtualVinyl serial number to receive the discount.
If you have the full Numark Cue, then you can crossgrade to VirtualDJ v6 Pro for only $49 - Please go to https://virtualdj.com/buy/ and enter your Cue serial number in the box provided to upgrade at a discount.
Otherwise, if you do not own the full Numark Cue (I.e: You have CueLE or a trial), you can upgrade from the free Hercules DJ Console Edition to Pro at a discount of 50% (I.e: $149 instead of $299.)
geposted Sun 14 Feb 10 @ 9:04 pm
