Does anyone have the midi map for the Denon 2500HD or are there any plannned release from Virtual DJ for Denon 2500HD midi map
geposted Fri 05 Feb 10 @ 1:37 pm
It is already supported and has been for some time now.
Please ensure that you have the latest firmware installed from http://www.denondj.com and you are running the latest version of VirtualDJ: https://virtualdj.com/download/updates.html
geposted Fri 05 Feb 10 @ 2:30 pm
The effects section is not mapped correctly ( echo/loop, flanger, and filter ). When pressed they perform beatgrind, brake, and backspin.
geposted Fri 05 Feb 10 @ 4:47 pm
You can map them manually to any effects or any other function of your choice. Go to CONFIG -> Mappers, choose the HD2500 in the drop-down list. Press + (Add) and press an effect button that you wish to map/change.
Enter one of the following (As appropriate) in the action: box:
effect 'echo' active
effect 'flanger' active
effect 'filter' active
geposted Sun 07 Feb 10 @ 1:57 pm
Thank you for your help. Finally a straight and easily understood answer.
geposted Wed 10 Feb 10 @ 5:28 pm
