I would be happy if i get the answer from someone from atomix but feel free to answer if you have an answer:
Will my Audio 4 DJ work with the mac version and can be used for TimeCode CDs???
(I have 2 CDJ400 so i'm not using my AUDIO 4 DJ alot, but the is a chance i will need it soon for some places with built in equipment)
also if the answer is NO - what else should i get so i could use TimeCodes?
geposted Sat 06 Feb 10 @ 5:57 am
Forgot to add - i'm using snow leopard.
geposted Sat 06 Feb 10 @ 11:16 am
Hello Aviry,
Yes, Audio 4 DJ is supported in VirtualDJ Pro in time code CD mode. With CDJ-400, you should take the MP3 Pro grade track https://virtualdj.com/products/timecode/cd.html.
geposted Tue 09 Feb 10 @ 5:14 am
VDJ isn't getting a signal from the AUDIO 4 DJ when a press play. (appears to be just on mac)
geposted Tue 09 Feb 10 @ 6:39 am
Im using 2 technics 1200's and audio 4 dj on a mac, no put signal. (rane cv02 vinyls)
geposted Thu 10 Jun 10 @ 3:42 am
