Hi Forum,
i want to buy a Behringer DFX-69.
(http://www.recordcase.de/lshop,showdetail,1114534352-31409,d,1114534352-31409,effektgeraete_filter_dj,0020102275,,Tshowrub--effektgeraete_filter_dj,.htm)
Did anyone already gain experiences with that?
Does it work with VDJ without problems?
Thanks for your infos.
JayDee
P.S. You can even watch my german post if your german is better than my english... ;-)
http://www.virtualdj.com/forum/display.html?topic=11706
JayDee
geposted Mon 16 May 05 @ 2:49 pm
nobody use it?? :-(
Or can anyone recommend me another effect-machine?
I use a pioneer DJM707.
geposted Tue 17 May 05 @ 11:32 am
Ok, i see. Nobody use it. I will test it. ;-)
I will buy it on June 4th in Münster @ Elevator DJ Flohmarkt...
You get the report later... I pray it will work.
Regards
JayDee
Regards
JayDee
geposted Wed 18 May 05 @ 10:53 am
what is this actually? =)
i mean.. which effects do you get with this? a lot of it you already have in VDJ.
how do you connect this to computer?
Dj Nikki
Dj Nikki
geposted Wed 18 May 05 @ 3:32 pm
i THINK it is audio based only no CONSOLE or remote to vdj
(maybe thru TCV somehow)
It will work sure for VDJ as it will work for an ordinary cd player, microphone, radio, vinyl.. thats what it seems to me
geposted Wed 18 May 05 @ 4:05 pm
i read describtion but no words about any usb connector.
geposted Wed 18 May 05 @ 4:18 pm
i connect it with my mixer (Pioneer DJM-707).
But there is a wheel on the effect-machine...
My hope is, that i can use the wheel for scrolling the songs in VDJ...
The original wheelsystem fromVDJ is too expensive...
geposted Wed 18 May 05 @ 6:19 pm
sorry but if it doesn't have usb it can't be supported by vdj. this is product you connect to your mixer and not to computer. it hasn't got any connection with computers.
to control songs you need hardware products supported by VDJ. you can find them here:
http://www.virtualdj.com/products/hardware.html when you can purchase them too.
you said "original wheelsystem fromVDJ" did you mean XP10 for 299€?
xp10 has its price because it is proffesional hardware.
you can control VDJ with many other products. look at link.
Dj Nikki
Dj Nikki
geposted Wed 18 May 05 @ 7:21 pm
