Not a problem with v2; I wasn't aware v1 of my slideshow did it either?
geposted Sat 20 Mar 10 @ 9:21 pm
My name is DJ Knightime, I have the Numark Cue program I can not play my Karaoke on it. What do I do, is it in the setting
geposted Tue 20 Apr 10 @ 5:15 pm
Go to "Effects tab then video effects option and click on "Keraoke" then click the center "Avtivate" button and it will turn on.
Joey....
Joey....
geposted Tue 20 Apr 10 @ 5:53 pm
Just curious on the status of SlideShow V2?
I'm doing a slideshow tomorrow and was just thinking.. man! version 2 would be awesome right now! ;-)
geposted Thu 27 May 10 @ 12:47 pm
Ya, I'm really getting anxious too Scott, especially where you have stated that the disabling of the slideshow now gives full priority of the second monitor back to another program if required, w/o causing a lockup upon use of the other program.
geposted Sat 29 May 10 @ 2:39 am
Had a weird thing happen with the original SBDJ Slideshow. I was using it this weekend with over 200 pictures supplied by the client..
at the end of the pictures it stopped?? yet at home with only a few pictures it automatically loops.. ???
weird..
weird..
geposted Sun 30 May 10 @ 12:55 pm
Are you sure it was the end, or did it get stuck reading a image it didn't agree with?
geposted Tue 01 Jun 10 @ 5:40 am
Not sure either way to be honest.. I stored their pictures on my C: drive, so I will have to take the rackmount out of the van and do some testing this week.
geposted Tue 01 Jun 10 @ 9:10 am
Try that, leave it running, then if it stops, note down the name of the file listed on the plugin's control panel.
geposted Wed 02 Jun 10 @ 4:46 am
Scott, How ya coming on V2 anyway?
geposted Thu 01 Jul 10 @ 1:56 am
Has version 2 been suspended for other projects you may be working on?
Or has it been released and I missed it somehow?
geposted Mon 22 Nov 10 @ 2:25 pm
It's not out yet I'm afraid...
geposted Mon 22 Nov 10 @ 6:18 pm
I havent been hanging around much..
Did the Slideshow V2 ever get released?
geposted Sat 21 Jul 12 @ 1:08 pm
I only see version 1.01
hey Scott, what ever happened to this?
geposted Fri 27 Jul 12 @ 9:16 am
Hi Scott,
Is the v2 updated ? " * You can now add/remove pictures to the folder dynamically - no need to reopen the folder or restart the plugin"
I don't see it in the download anymore, only the v1.01 exist.
Thanks
Thanks
geposted Wed 19 Jun 13 @ 9:10 am
Is there a way that transparency on PNG files could be supported? I would like to run multiple graphics that show my text to screen number & Twitter handle, without changing them manually in Show Logo.
geposted Sun 30 Jun 13 @ 7:46 pm
Just in case...
Rotate left or right 90 degrees for portrait that are sideways.
geposted Tue 02 Jul 13 @ 10:31 pm
My regular Slide Show works with all it's issue but SBDJ_SLIDESHOW is installed but there is no Activate or anything else other than the name in my Video Effect Plugin. What should I do?
geposted Mon 09 Dec 13 @ 5:27 pm
You'll need to update your runtime libraries - you're missing a C++ or DirectX one. I can't remember which C++ that plugin uses now!
https://virtualdj.com/forums/95136/VirtualDJ_Plugins/Plugin_not_working__Controls_not_showing__DX_File_Missing_______Read_this_before_posting_____.html
geposted Mon 09 Dec 13 @ 7:50 pm
where is this version 2.0? I only see in the download section v1.01.
geposted Sat 14 Dec 13 @ 10:23 am
