yes i just bought v2.1 but 4 some reason im having a problem with Internal database corrupted and invalid skin now i was using a crack version but i don't think that makes a different does it. well i really would like to start this program but i can't so ill appreciate if some1 that had this same problem help me out Thanks. my bad the topic is version 2.1 NOT v2.01
geposted Mon 16 May 05 @ 11:40 pm
U seed support to unscrew that for ya.
Top of the page right corner.
geposted Mon 16 May 05 @ 11:46 pm
First of all, welcome into legality!!
the internal database corrupted is a problem with the "internal database.xml" file, try to cut it out of the virtualdj root folder. and see if there is still the same problem.
for the skin you must change something in the windows registry.
I'll post here when i find what to change.
wait two minuts.
Jérémie
wait two minuts.
Jérémie
geposted Mon 16 May 05 @ 11:47 pm
For the skin:
"Start" menu then "Execute" or "load" (don't know the correct word in english). You write "regedit"
-> "HKEY_CURRENT_USER"
-> "Software"
-> "VirtualDJ"
-->>> Look for the "Skin" chain
-->>> Mouse right clic "Edit"
-->>> Enter "Default:1024x768"
-> "Software"
-> "VirtualDJ"
geposted Mon 16 May 05 @ 11:51 pm
hey u think u can tell me step to step thanks i new so i don't where to go on the computer
geposted Mon 16 May 05 @ 11:57 pm
Click on start in windows then follow what i said above.
geposted Tue 17 May 05 @ 12:04 am
ok i click on start then where do i go
geposted Tue 17 May 05 @ 12:05 am
on Run i think that's the word windows uses in english. If you are using windows XP it's on the bottom right of the pannel that is opened when you click on start.
Then you write regedit and tap enter.
geposted Tue 17 May 05 @ 12:09 am
hey thanks how about the internal database corrupted how do u the root folder. how do u get there??
geposted Tue 17 May 05 @ 12:12 am
hey i went to HKEY_CURRENT_USER" and i dont see software
geposted Tue 17 May 05 @ 12:13 am
try HKEY_LOCAL_MACHINE THEN.
If you want more help i'll be on the chat (bottom of virtualdj.com/forum)
geposted Tue 17 May 05 @ 12:17 am
For the internal database:
go to c:/Program files/VirtualDJ then find the file "internal database.xml" right clic on it and click on cut.
go to your desktop and right clic then paste. Load VDJ and there shouldn't be the database problem anymore.
geposted Tue 17 May 05 @ 12:21 am
