I am not able to hear what is being played on the other deck to beatmatch, while another track is playing on the other deck. I can only get the headphone button to go to one deck and not both at the same time. Do anyone know how to make where I can listen to both tracks.
geposted Tue 17 May 05 @ 2:56 am
Buy the software.
geposted Tue 17 May 05 @ 5:10 am
The full version allows user to select many soudncards at the samt eime and many config.
Yes with the full version you can prelisten; no problem for that.
You can select many outputs (for example: one stereo output for deck a, another one for deck B, also another one for sample, another one for headphone).
geposted Tue 17 May 05 @ 10:04 am
