I just purchased this virtual dj but do i need a second sound card to cue through my headphones. i am using a brand new laptop. IF a second soundcard is required which do you recommend. thnx
geposted Tue 17 May 05 @ 4:27 pm
Please register your serial number in your profile first.
geposted Tue 17 May 05 @ 4:33 pm
Check out m-audio.com. They have some good external sound cards and this would help you. I'm working with Mobile Interface Audiophile USB and this has been working out well. Good luck. Hey, what kind of top do u have or get?
DC
DC
geposted Tue 17 May 05 @ 6:25 pm
Also remember that you will need an RCA output for mixers and/or amps. With the RCA's, you will be able to connect to any mixer anywhere. Very cool thing! Peace.
geposted Tue 17 May 05 @ 6:33 pm
>dlocko
You can use your headphones even with one soundcard but You need 4.1 (or 5.1/7.1/9.1)
compatible soundcard. It means you must have the rear and front outputs on your soundcard.
C ya !
C ya !
geposted Tue 17 May 05 @ 7:53 pm
This function is disabled in the demo version.
geposted Tue 17 May 05 @ 10:07 pm
thnx if i were to purchase the Audiophile usb external soundcard, is it just plug in and run the headphones through it, or is there some serious configuration that has to be done. I have been recommended to buy a sony laptop but what is your opinion.
geposted Tue 17 May 05 @ 10:47 pm
You would be able to use the headphones through the laptop's headphones jack and sound out through the audiophile usb soundcard. In the vdj program there's a setting that you would use (for 2 cards that is)... but you have to remember that a laptop doesnt come with 2 sound cards. You would have to get an external card.
geposted Wed 18 May 05 @ 2:25 am
Echo Indigo DJ PCCARD. Dual Stereo output via two 1/8" TRS jacks.
geposted Wed 18 May 05 @ 2:37 am
thanx now i will buy the external sound card and start using virtual dj out.
geposted Wed 18 May 05 @ 9:24 am
