k when i click on the alien i can only listen to tracks when in third mode ASIO
when i'm on virtual dj i can only listen to the track i'm playin live on me speakers??? strange
i wanna be able to pre-listen to the other song and blend it int with the other thats playin (live)
when i go to conifg then sounds.....
it has the 6 pics 3 sound cards pics and the others are speakers and onewith headphones??? which do i click on????
then when i click on the sound cards i have 3 to choose from hercules, primary sound card & realtek ac97 audio?
my out put sound is one cable from 1-2 analog output
so bit stuck plzzzzzzzzzz?? also does it matter where
geposted Tue 17 May 05 @ 7:31 pm
To prelisten by a different output you need the full version which allows you to use many soundcards and many sound config.
geposted Tue 17 May 05 @ 7:46 pm
otherwise just set hercules as primary sound card and it will work. but for all functions, buy full version
Dj Nikki
Dj Nikki
geposted Tue 17 May 05 @ 7:51 pm
where do i do that plz??
geposted Tue 17 May 05 @ 7:54 pm
buy full version?
here:
http://www.virtualdj.com/purchase/
here:
geposted Tue 17 May 05 @ 7:58 pm
