Can anybody give a recomendation for a usb or other camera to use for live video with virtual dj.
Thanks
Thanks
geposted Mon 22 Feb 10 @ 3:47 am
We use a switch box to change from the computer, DVD player, to live camera. It reduces the load on the computer and gives you the flexibility to switch between 3 or 4 different sources. Radio Shack has a switch box for 21.00 that will suffice. You will have to use a few different adapters to get everything to work right, depending on your video display. Be ready to adapt to a variety of connections and be sure to set up and test everything way before you do a gig with this stuff. You can use a video camera with a 0 lux rating so that low light shots look better. You can use an older video camera that has RCA out puts for this. I hope this helps.
geposted Fri 26 Feb 10 @ 6:46 pm
Have you not tried the picture in picture feature with the free firetext plugin, try it you will be pleased I'm sure.
geposted Fri 26 Feb 10 @ 7:27 pm
check out what you can do with the plugin once you get your camera...
geposted Sat 27 Feb 10 @ 7:10 pm
I have tried using a camera a few years back with VDJ, but found that it chewed too much cpu usage, for any decent quality resolution shown on the screens. Bit of a waste of $200 for a great webcam!
Thing may be better these days.
geposted Sun 28 Feb 10 @ 8:39 am
reports from guys using the Firetext plugin with cameras are good. As you can see above that was just a tv feed into the PIP feature, cams look fantastic when showing the audience.
geposted Sun 28 Feb 10 @ 9:19 am
Saw this at a local store. http://industrialcomponent.com/unibrain/ubwebcam.html Its from a company that makes "industrial camaras" http://www.unibrain.com/ they are firewire capable , stream live and 2 can be connected in series,vista capable, even Linux but not sure if they zoom and whether or not it would work in certain systems but...
geposted Sat 27 Mar 10 @ 6:18 am
Wait there is a plugin that let's you mix a live video feed from your computer, or camera hooked up to your computer, with other video footage?
geposted Sun 15 Aug 10 @ 1:25 pm
Sorry,You must be a License user...Cheers!
geposted Sun 15 Aug 10 @ 6:45 pm
