Hi,
I'm using dj control mp3, with version 3.4 of the software (home version I believe)
I would like to install the long brake and delay plugin but it says unable to find software.
is there any reason for this?
ty
ty
geposted Thu 25 Feb 10 @ 6:55 am
Where did you download the plugins from?
geposted Thu 25 Feb 10 @ 2:59 pm
https://virtualdj.com/addons/effects.html
does it matter where i installed the main software to?
geposted Thu 25 Feb 10 @ 5:08 pm
No. If you look underneath where you downloaded the plugin from you'll notice a version requirement though.
I'll confess that I don't know what plugins work on home edition either though.
geposted Thu 25 Feb 10 @ 5:44 pm
I remember using them before so it must be possible, unless you have locked it all up.
is it not possible to update my version to 4.1?
geposted Fri 26 Feb 10 @ 12:19 pm
As I say, I've never used the home versions so don't know what plugins work and what don't!
The latest version for you will be in your download center.
geposted Sat 27 Feb 10 @ 8:18 am
The old DJC version is only up to V3.4.1.
But you do have a discount as you have the djc version to upgrade to pro;)
When you download the plugins, please look at what version is required at least or any specific indication.
Regards;)
geposted Sat 27 Feb 10 @ 11:00 pm
hey please I lost my serial number from dj control mp3 . If you have some i ll be very happy. thanks you
geposted Thu 06 May 10 @ 3:10 am
You'll need to contact Hercules support.
geposted Thu 06 May 10 @ 6:38 am
