Are there any mappers for the Denon DN-HC4500 available for version 6
I am a previous PCDJ VJ user that absolutely loved the Phantom mapper plugin in. I see it is available for Virtual DJ 5.2 but there is no mention for version 6.
Any suggestions??
Thanks!
Any suggestions??
Thanks!
geposted Thu 04 Mar 10 @ 12:30 pm
Traditional DLL mappers are obsolete; you can now DIY map a controller any way you like without any 'programming' knowledge.
geposted Thu 04 Mar 10 @ 12:54 pm
The phantom mapper had some advanced functions that I am not sure how to possibly enter. it created several "modes" to change certain buttons to do differnt things depending on the mode. it also changed alot of the display.
Does anyone have any idea how to do that? I see how you can change one key at a time but not positive I can change everythign like it was.
Thanks!
Thanks!
geposted Fri 02 Apr 10 @ 9:57 pm
You can find more info in here:
https://virtualdj.com/wiki/VDJscript.html
If you mess up your mapping, you can delete it and you will always have VirtualDJ Default mapping without change.
geposted Sat 03 Apr 10 @ 4:57 am
There are some examples on the following page:
https://virtualdj.com/wiki/VDJScript%20Examples.html
geposted Sat 03 Apr 10 @ 12:58 pm
