hey every one
can any one tell me if the skin resolution shoulxd be on maximize?
what are the differences?
thanks
thanks
geposted Sun 07 Mar 10 @ 7:15 am
this may help you, new release... https://virtualdj.com/forums/125240/General_Discussion/_NEWS__VirtualDJ_v6_0_7_released.html
geposted Sun 07 Mar 10 @ 7:37 am
i saw the update and i know it has a feature for the skin...but i dont really trust it. as when i launched the software it still said your the skin you are usign is a different etc..
i just want to know if a skin should be maximized or not?
geposted Sun 07 Mar 10 @ 8:47 pm
VDJ uses extra resources to resize a skin. My backup laptop (Pentium M 1.6) doesn't cope with resizing a skin. It runs fine windowed or running a skin fullscreen at native resolution.
If you have a reasonably quick computer, it should be able to resize skins ok.
I would recommend using a skin that is the same size as your monitor and running it maximized. If you prefer not to run maximized, use a skin that is smaller than your monitor.
geposted Mon 08 Mar 10 @ 3:29 am
Thanks man.
geposted Mon 08 Mar 10 @ 7:02 am
