Hi
the djm 2000 offer a new 7 band frequency mix mode, which overhaul the typical crossfader.
I know my rmx has 7 knobs which i wouldn`t use if this feature can be integrated into the engine and a skin.
(2 high knobs, 2 mid knobs, 2 low knobs + left right knob)
The visualization is just another feature, the main thing is to get the 7 band freq to work properly.
geposted Sat 13 Mar 10 @ 10:36 am
have you actually used the djm2000 ?
can you set the freq.s on each opf those 7 bands? or are they preset?
geposted Sat 13 Mar 10 @ 11:10 am
Frequency crossfading can already be done. To use a 7-band EQ someone would could write a suitable plugin. I experimented with an alternative EQ engine plugin, as have a few others.
geposted Sat 13 Mar 10 @ 12:16 pm
so i have to use a plug-in. I see there is a 16 and 32 eq plugins, so i would have to create my own plugin.
Can we assign this plugin to interact with knobs on a midi controller ?
geposted Sat 13 Mar 10 @ 7:20 pm
Yes you can map plugin sliders to MIDI controls.
The new plugin would have to replicate EQ functionality and manually implement frequency fading between decks but it's entirely possible to do.
Personally I'll stick to my 3-band EQ and manual fading :)
geposted Sun 14 Mar 10 @ 10:30 am
well i mix electro, so when i heard that 7 band worked nicely and i have the knobs available, i prefer giving it a try.
My plugin spec :
Dsp plugins: Audio effects that interact with the sound.
Device plugins: Mappers that let you redefine how a specific hardware controller interacts with VirtualDJ.
A mix of both i think ?
My plugin spec :
geposted Sun 14 Mar 10 @ 10:40 am
No; the device mapper class is obsolete now anyway.
geposted Sun 14 Mar 10 @ 6:22 pm
