This might have some uses and for only $45.
http://www.griffintechnology.com/products/powermate/
Bargler
Bargler
geposted Fri 20 May 05 @ 6:45 pm
i was looking at this http://www.electronicsoutfitter.com/store/sxprs.html using TCV and map the buttons for easy shortcuts
geposted Fri 20 May 05 @ 7:10 pm
That looks promising. Let us know if you check it out.
Bargler
Bargler
geposted Fri 20 May 05 @ 7:12 pm
whats nice is that it has 2 wheels, the inner is a free moving jog wheel, and the outer is a spring loaded one, (moves only left/right) there was a guy how took a optical mouse apart and mounted a free spinning cd to it, and could scratch with that, this was back with atomixmp3, i had emailed him but do to language difference i never understood how he did it. i do however have the plan in my head, it just doesn't seem practical anymore since i'm waiting my TCV as we speak
geposted Fri 20 May 05 @ 7:38 pm
its touch sensitive also... it does at least have a plate in the middle you can press...
Hmm, interessting
Hmm, interessting
geposted Fri 20 May 05 @ 7:41 pm
the jog wheel looks just like my old Denon 2500 cd players.
Ewout
Ewout
geposted Fri 20 May 05 @ 11:06 pm
it would be great if vdj would team up with a company which produces professional external controllers. I have an xp10 which works great, however i wish the plastic buttons were more of the industrial standard that you find on pioneer and numark.
I like the look of the citronic cd scratch table. replica of cdj 1000 except i think its a conductive plate like the xp10.
geposted Sat 21 May 05 @ 2:28 am
Very interessting.
Had anyone test it already?
Works it with VDJ3.0 ????
geposted Mon 23 May 05 @ 8:45 am
