Forum: Old versions
Topic: Rmx and CDJ800's!!
How do folks. Ok i have a general wondering. I'm working in a new club and they have 2 CDJ800's sitting doing nothing whilst i use my RMX. Am still using the club mixer for previewing and cue'ing the next song.
Wats needed for me to hook up to the the 2cdj's and use them as time codes. And will there be any issues
Thanks Chris
geposted Sun 14 Mar 10 @ 1:03 pm
Just get some RCAs and plug them into the inputs, I forget if you have to switch to source or not as I don't have an RMX anymore, but that'll only take second to figure out. Next download the timecode off the hardware page and burn some CDs as SLOW AS POSSIBLE, its a good idea to have at least two sets just in case. Then boot up VDJ, go to audio, switch to timecodes and choose timecode type .Insert the CDs and press play, then calibrate if necessary. You should be good to go at that point. Now you may have to mess with latency settings and what but there's other threads that specifically address that for the RMX.
Cheers dude i'll give it a try :)
