Hi,
I am having trouble finding video mixing skins for 1440x900 res. I really like the virtual pro 6 but the res is not quite right for me. Does anyone know if there are some video skins at the res I need
many thanks
Justin
many thanks
Justin
geposted Fri 19 Mar 10 @ 3:06 am
there are quite a few in the skins section, just depends what you want to do really, check out dj touchdans black sheep, i just love that one.
geposted Fri 19 Mar 10 @ 3:21 am
Hi Tayla,
I agree the skin is very good, I like the size of the font on the pro 6 version skin over the black sheep one. Apart from that, I think its fantastic
many thanks again for the help on the clip bank stuff
Justin
Justin
geposted Fri 19 Mar 10 @ 9:26 am
You can easily change the font and it's size by editing the skin XML. You just need to use notepad and "replace" the text string with the new font name or size. Piece of cake!
geposted Fri 19 Mar 10 @ 9:54 am
@discojay - as keith above says you can easily change the size of the font yourself.
If you unzip the skin file. Then open the .xml file within (use notepad or similar)
Near the top of the file you will find this section:
<browser>
<size width="1429" height="419"/>
<pos x="5" y="482"/>
<text font="Verdana" size="13" color="#FFFFFF" selected="#000080" stripes="#181818"/>
<options font="Tahoma" size="9" color="#FFFFFF" selected="#000000" over="#99DDFF"/>
<widgets font="Virtual DJ" size="10" color="#99DDFF"
facecolor="transparent"
lightcolor="#808080"
shadowcolor="#606060"
highlightcolor="transparent"
darkshadowcolor="transparent"
trackcolor1="transparent"
trackcolor2="transparent"/>
<customicons x="830" y="1491"/>
</browser>
Just change the highlighted section to a size that suits you better - glad you like the skin though.
<browser>
</browser>
geposted Fri 19 Mar 10 @ 10:06 am
it's alright dan if he hadn't, i would have shot him... lol
glad you like the clipbank stuff justin, you got access to my clipbank files anytime you want remember.
geposted Fri 19 Mar 10 @ 11:42 am
Thanks for your help guys, worked a treat.
Another question,
If I wanted to change the size of the time counters, is this possible?
many thanks
Justin
Another question,
many thanks
Justin
geposted Fri 19 Mar 10 @ 1:14 pm
Did you try this one?
http://www.virtualdj.com/addons/8427/VirtualDJ_6_-_1440x900.html
geposted Fri 19 Mar 10 @ 1:50 pm
I want to be able to see video playing
many thanks
many thanks
geposted Fri 19 Mar 10 @ 1:52 pm
thanks to this thread i finally got that problem solved,Had Resized A skin but when I did the Browser fonts "SHRUNK" also !! needless to say all titles were in MICRO SIZE ! Thanks guys ! You got me to overcome my XMLphobia !...TouchDan...U ROCK !!
geposted Sun 21 Mar 10 @ 6:34 am
many thanks
many thanks
Try my MultiFunctions skin. It's based on VDJ 6 PRO (with a lot more features) and is video mixing compatible :)
geposted Thu 25 Mar 10 @ 9:39 pm
How can you change the colour that a skin uses? For example, if I want to change the colour of the two beat keepers at the top of the skin, how would you do it?
I would like to experiment with different colors to see what I like best
geposted Fri 26 Mar 10 @ 9:37 am
All colors are defined by parts of the skin BMP file.
Except for the text colors that are defined in the XML.
geposted Fri 26 Mar 10 @ 10:30 am
So what would I be looking for in the XML for the text color?
geposted Fri 26 Mar 10 @ 1:32 pm
it all depends on the skin your using, but if you go and find the section that says browser your there, you can rename it by replacing the colour code with your own choice or simply replacing the colour code with red, blue , white or whatever.
made this nearly two years ago so it's pre youtube hd stuff, hope you can make it out...
looks like a new one needs to be made.. lol
geposted Fri 26 Mar 10 @ 2:41 pm
