Forum: Old versions
Topic: Vestax VCI-100 pitch bend and vinyl mode bug
This is an update to an earlier post (see bottom for link), since I have learned a bit more now.
I have the latest trial of VirtualDJ - 6.07, and there seems to be a bug with two items:
Jog wheel / pitch bend:
- when moving the edge of the jog wheel continuously for a few seconds, the pitch bend amount increases (correctly, as intended)
- BUT, when releasing (stopping spinning the jog dial), the pitch stays "bent" at that very high (or very low) level - it does not return to normal
- how do I adjust the VDJscript to tell the pitch bend to return to normal (zero) after I stop spinning the jog dial around?
Vinyl mode button:
- the vinyl mode button does not do anything
- I have tested this using MIDI LEARN but nothing registers when pressing the vinyl mode button
- is this a bug? I need this button to toggle vinyl mode on and off.
This is a serious issue for me since I cannot accurately test the software to decide to purchase if the pitch bend acts like this.
Since I am on a trial, I cannot download other users' xml MIDI maps to see if these fix the problem.
As for the vinyl mode: it is also important to have the ability to switch vinyl mode on and off, because very often I accidentally touch the metal part of the dial, activating a scratch when I am trying to do a pitch bend.
Please help / advise! Thanks!
Old post:
https://virtualdj.com/forums/125764/Hardware_Technical_Support/Pitch_bend_and_SYNC_with_Vestax_VCI-100.html
geposted Sat 20 Mar 10 @ 2:06 pm
