Forum: Old versions
Topic: L/R stereo split in VDJ v.2.1.
Hi everybody !
I'm a musician, and i'm using VDJ V2 as a very helpful tool to score tabs.
I would like to listen only to the left channel or only the right one.
Is there a way to split the left and right channels in VDJ 2.1 ?
Thanks in advance.
geposted Sun 22 May 05 @ 10:49 am
do you have computer connected directly to amplifier?
without any mixer? usualy mixer has PAN control on it. otherwise you can use effect called "Balance" by Ekinox
https://virtualdj.com/download.html#addons
you'll find it under plug-ins
Dj Nikki
I Thank you all for your support.
You're welcome mauw; don't hesitate if you have some other questions.
i try this it's not good we need it in the software like a nub in of the skin
i would like to see in skin too.
ok i always use external mixer to do this but it would be welcome in skin ;)
Dj Nikki
