Hi guys, is it possible to map the Akai LPD8 midi controller to activate various clips in "Clip Bank". And what are my chances of getting a camera input added to the video effects menu?
Hopefully the warbling issues with my Denon S3700 controller will be worked out so i can start using 6.0.7 soon...
geposted Thu 25 Mar 10 @ 1:06 am
If you aren't aware of it ... https://virtualdj.com/addons/10154/Akai_Lpd8_Def___Mapper.html
... and mapping the Clipbank can only be done to activate it and not pick which effect to use.
Yes, we are working on the issue ....
geposted Thu 25 Mar 10 @ 1:54 pm
Glad to hear the issue is being worked on... Not that i had any doubts. :-) I have no problem activating clip bank using my Denon controller in 5.2.1. I was hoping there was a way to change clips using the pads without having to open the effects window to point and click.
Thanks for the info
Thanks for the info
geposted Thu 25 Mar 10 @ 7:01 pm
You can map buttons or keyboard shortcuts to the following:
video_fx_select 'ClipBank' & video_fx_button 1
(To map the other 11 clips, change the button number appropriately.)
And the following to toggle clipbank itself on/off:
geposted Thu 25 Mar 10 @ 8:28 pm
Awesome, thank you! I'll give it a shot
geposted Thu 25 Mar 10 @ 9:49 pm
Jp if i'm not mistaken isn't the first one button 0?
geposted Thu 25 Mar 10 @ 9:54 pm
I could not get this to work... bummer.
geposted Tue 30 Mar 10 @ 11:38 am
worked for me. Thanks!
geposted Sat 24 Apr 10 @ 4:30 pm
could someone do me the biggest favour
just a student/ bedroom Dj
it was my birthday the other day and i got akai lpd8 but i cant play with it at all :(
download https://virtualdj.com/addons/10154/Akai_Lpd8_Def___Mapper.html
and send the zip/files to
i'm a graphics student
in return i could make you a sick dj poster/background
geposted Sun 23 May 10 @ 5:23 am
Please do not try this again.
Downloading of add-ons is only permit for licensed users.
Email removed as well.
geposted Sun 23 May 10 @ 8:04 am
I am very new to VDJ7... just bought basic version for now and just picked up LPD8 controller by AKAI
My needs are really simple... I just want to cue up music tracks on 4 decks and be able to click Pad 1-4 to play deck 1-4.. simple enough? Possible?
I also would like to have the other 4 pads to run sound effects/sampler selections.
Is that all possible through the Pro Version and downloading the mapper for the LPD8 Controller (I have tried to download it but it says my license level does not allow me :-\ )
Any input is appreciated!
Cheers,
Bruce
Cheers,
Bruce
geposted Fri 04 Feb 11 @ 12:34 am
Sorry, VirtualDJ Pro Basic does not support any external MIDI controllers. It is for mixing using your mouse and keyboard only.
This is clearly stated on the product purchase page https://virtualdj.com/products/basic.html and the product comparison page https://virtualdj.com/products/comparison.html
To use external controllers, you will need to upgrade to VirtualDJ Professional at a discount: https://virtualdj.com/buy/
Mappers and tools can only be downloaded registered licensed VirtualDJ Pro users.
In future, please also open your own new topic rather than bumping an old one from last year.
[Topic closed]
[Topic closed]
geposted Fri 04 Feb 11 @ 4:29 am
