I used these effects when I was using Windows. I would really like to maintain using MAC version of VDJ and not have to bootcamp, work a solution so I can keep a music library for Windows and one for MAC.
TexZK's_Flanger
http://www.virtualdj.com/addons/2050/TexZK_s_High_Quality_Flanger_.html
Deun Deun's Isolator
http://www.virtualdj.com/addons/1608/Isolator.html
macouter - Cutoff LFO
http://www.virtualdj.com/addons/477/Cutoff_LFO.html
They all have the source code available (it looks like.) Is it possible (easily, as in less than a couple hours work) to port them to MAC? Or has anyone done so or could do so easily enough? I would be grateful. Perhaps even paypal grateful? :) Would also be great to post it in the downloads section so it could be tested and re-usable to others too.
Thank you in advance!
Chad
TexZK's_Flanger
Chad
geposted Sat 27 Mar 10 @ 8:18 pm
Isolator doesn't appear to have the source available, but the others do. I can have a look at porting them; I'll contact the authors for their permission too.
geposted Sun 28 Mar 10 @ 7:10 pm
Thank you.
geposted Sun 28 Mar 10 @ 8:27 pm
I'm also very interested in getting the Isolator for Mac too - any joy with getting in touch with Deun Deun?
geposted Wed 30 Jun 10 @ 4:38 pm
Nope. I sold all my VDJ related hardware and bought an Allen and Heath Xone DX for ITCH. It also works with Traktor. I tried to map with VDJ because I would then have my pic of the big 3 DJ program; however could not even get music to play through it and 1/2 the functions to map properly. I posted to see if anyone had success, but never got a response.
ITCH and Traktor have a plethera of FX for use on both Windows and MAC. If they break or dont work, i get instant response to help... and if it is broke, the fix goes into the next build. I spent alot of time and money to get VDJ where I needed it to. But when I lost all the FX when going to the MAC and the answer was "go beg for development" I had to jump ship.
I am finding the Xone DX and ITCH combo to be VERY powerful. Many FX out of the box and more to come along with the Ableton Bridge for ITCH 2.0. Pretty happy.
Sorry, I know it isnt what you are looking for... but that is how I solved the "no FX" problem on VDJ.
geposted Wed 30 Jun 10 @ 8:57 pm
