Forum: Old versions
Topic: How to aggregate 2 behringer uca202 sound cards?
Hi,
I need some help aggregating 2 behringer uca202 in mac osx snow leopard. I've opened the audio midi setup and the 2 sound cards are labelled usb audio CODEC DEMO. i attempted to create a new aggregate but the two carsd aren't in the options of devices to aggregate.
thanks for your help
cheers
geposted Mon 29 Mar 10 @ 6:57 am
Hello,
Here you could find how to setup an aggregate device in Mac:
https://virtualdj.com/wiki/Denon.html
Take the info, and of course the names... you will see UCA-202 and not Denon devices in your SOUND/MIDI config, but the way to add an aggregate device is the same.
Thanks but he problem is i can't select the uca202 to aggregate cos its not in the aggregate menu.
UCA-202 is a very cheap sound card, if it cannot be used as an aggregate device, then it is not CORE compatible with Mac.
You may need another sound card that is compatible. You can use Hercules DJTrim or Echo AudioFire 4 to work with you Mac+VirtualDJ Pro+ Timecodes.
is there any way to make it core compatible? Because i'm sure this works as i have read about it and seen it done in a few places.
Or it is or it not Core compatible, there nothing to do. You maybe see this with Windows, but for Mac this is the way it is.
