Forum: Old versions
Topic: [HS5500]
WAZ UP EVERYONE!!! iM lOOKING FOR SOME HELP...
IVE JUST RECENTLY UPGRADED, GOT THE 6.0.7 VERSION AND IM TRYING TO RUN MY DN-HS550
IVE ONLY GOT ONE PLAYER...
ONE ISSUE IVE BEEN HAVING IS THAT AFTER A LIL USE, THE PLAYER JUST STOPS COMPLETELY WORKING!!!!!!
ANOTHER ISSUE IS THAT, I CANNOT RUN BOTH DECKS AT THE SAME TIME!!!! WHEN I HIT THE LAYER BUTTON, IT WILL STOP THE CURRENTLY PLAYING DECK AND THEN START THE OTHER....... IT WILL ALLOW ME TO CHANGE FROM THE LEFT AND RIGHT DECK, BUT WILL STOP ONE SIDE TO GO TO THE OTHER!!!!!!
IVE BEEN HAVING ISSUES WITH THIS PLAYER SINCE DAY ONE... ALL THE RESEARCH I DID BEFORE PURCHASING MADE IT SEEM SO NICE AND EASY ~~~JUST PLUG AND PLAY~~~
GUESS NOT!!!!! JOKES ON ME!!!
NOW I HEAR THAT VISTA DOES NOT PICK UP ON MIDI CONTROLLERS, ANYONE ELSE HEARD OF THIS?????
PLEASE HELP ME!!! LOYAL FAN OF VIRTUAL DJ!!!
geposted Tue 30 Mar 10 @ 2:48 am
THANX FOR ANSWERING BACK...
ACTUALLY I HAVE VIRTUAL VINYL 6.0.7 FULL PRO VERSION... I HAVE IT REGISTERED IN TO THE NUMARK WEBSITE.....
THE THING IS THAT NUMARK DOESNT HAVE A FORUM AS WELL AS VIRTUAL DJ, BOTH PROGRAMS ARE PRETTY IDENTICAL..... SO I FIGURED SINCE IVE HAD NO LUCK ANY OTHER WAY........ ID TRY HERE WITH YOU GUYZ, & ACTUALLY HAVENT HAD MUCH A RESPONSE ANYWHERE ELSE.... SO ONCE AGAIN I THANK YOU FOR RESPONDING!!!!
I HAVE THE ASIO 2.10 DRIVER INSTALLLED... FIRMWARE 1400 IN THE MEDIA PLAYER.... IM RUNNING THE NEWEST VIRTUAL VINYL 6.0.7.... (WHICH HAS THE SAME CONFIGURATIONS AS VDJ)..... I'VE DONE THE PRESET INT ON THE PLAYER........ ADJUSTED NOTHING BUT THE JOG TRNS INT. TO 10ms CAUSE IM RUNNING VISTA..........
AND YET....... I CAN ONLY PLAY ONE DECK(LAYER) AT A TIME, NO MATTER HOW I HAVE ANY CROSSFADERS ADJUSTED!!!!!
IT WILL NOT ALLOW ME TO SWITCH FROM ONE SIDE TO THE NEXT WITHOUT CUTTING OUT THE DECK THAT IS CURRENTLY PLAYING!!!!
OTHER THEN THAT SOMETIMES THE SOFTWARE LIKES TO BOOT THE PLAYER OFFLINE, AND SPEEDS WILL VARY AFTER ANY SCRATCHING OF THE PLATTER(LOTS OF BEND) WHICH I CAN DEAL WITH THAT LATER........
PLEASE PLEASE PLEASE!!!! HELP ME OUT!!!! THIS PLAYER HAS BEEN ONE HELL OF A NIGHTMARE THAT I NEVER EXPECTED!!!!!!
You can still add your VV serial number here... Should get you the VV icon under your avatar ;-)
Roy
Please register your serial number in your profile here ... once that is done I can better help you with a different download that you can install. But, I can not do that until you register your license - https://virtualdj.com/users/edit.html
Also, please do not type in all capital letters. It's difficult to read and is also considered shouting by most Internet users.
