hi can itch software use with the hercules rmx
geposted Wed 05 Oct 11 @ 6:03 am
No.
geposted Wed 05 Oct 11 @ 6:51 am
<map value="JOG" action="deck 1 effect active ? action_deck 1 ? deck 1 effect slider 1 : deck 1 effect slider 2 : deck 2 effect active ? action_deck 1 ? deck 2 effect slider 1 : deck 2 effect slider 2 : jogwheel & loop_move" />
i have a problem with this jogwheel & loop_move how to fix it ? It´s work but i have always loop move and jogwheel together.
geposted Sat 08 Oct 11 @ 7:11 am
try this, it should split the action so it only does the loop move when the deck is looping
loop ? loop_move : deck 1 effect active ? action_deck 1 ? deck 1 effect slider 1 : deck 1 effect slider 2 : deck 2 effect active ? action_deck 1 ? deck 2 effect slider 1 : deck 2 effect slider 2 : jogwheel
if you have a shift mapped it would be better to have loop move mapped the the jog only when the shift is enabed, the jog is always usefull as a jog so you can make adjustments when needed, and you will find that you will only set the loop position at the start and not need it again, effectively wasting the use of your jog.
var 'shift' ? loop ? loop_move : jogwheel : deck 1 effect active ? action_deck 1 ? deck 1 effect slider 1 : deck 1 effect slider 2 : deck 2 effect active ? action_deck 1 ? deck 2 effect slider 1 : deck 2 effect slider 2 : jogwheel
you can change the first jogwheel to something else if you want when shifted, and you would need to change the shift to whatever yours is called.
you should also buy a legit version of pro
enjoy
enjoy
geposted Sat 08 Oct 11 @ 7:40 am
What's up VDJ World,
So I am trying to add a sampler to my RMX controller with buttons 1-6. How can I do that? Thanks!
geposted Mon 13 Feb 12 @ 11:29 pm
Hey guys. Im having some trouble finding the correct mappings on the site. I've clicked every link and i still can seem to find the mappings i want. Please help me get these. I have a hercules 4MX.
Mapping list:
Button 3- cue 1 (Plus) Hold for 5 seconds to delete that cue
Button 12- Flanger with the FX knob to control the parameters
Source Button - is a loop move when a loop is active but the jog wheel moves the loop
Pitch bend + - activates sample 1
Scratch button - activates scratch mode
If anyone could please help with these mappings it'd be most appreciated!
Mapping list:
geposted Tue 06 Mar 12 @ 2:57 pm
ok in the rmx is it posible to make button source into multi shift allow me to use one shift to do 6+6 and the other side shift to do 6+6 different so then 24 totall possible things. source left effects/loops and source right cue/samples
2
A
1- loop 2
2 -loop 4
3 -loop 6
4 -loop 8
5 -loop16
6 -loop 32
B
1- effect
2 -effect
3 -effect
4 -effect
5 -effect
6 -effect
c
1hot cue
2hot cue
3hot cue
4hot cue
5hot cue
6hot cue
D
1sample
2sample
3sample
4sample
5sample
6sample
i had a issue with the source button not working as a shift is there something im missing in my codeing?
2
A
1- loop 2
2 -loop 4
3 -loop 6
4 -loop 8
5 -loop16
6 -loop 32
B
1- effect
2 -effect
3 -effect
4 -effect
5 -effect
6 -effect
c
1hot cue
2hot cue
3hot cue
4hot cue
5hot cue
6hot cue
D
1sample
2sample
3sample
4sample
5sample
6sample
geposted Thu 13 Sep 12 @ 2:46 am
