my set up works great but not when the crossfader is in the middle? it skips beats and acts all laggy when i play two things at the same time.??
geposted Fri 02 Apr 10 @ 12:57 pm
Please tell me what are your computer specs (Processor, RAM, Free Hard disk Space, Soundcard, Videocard, Operation System (32 bits, 64 bits))
geposted Fri 02 Apr 10 @ 6:27 pm
procc: AMD turion 64 X2 2.00 GHz
ram: 1662 mb
system : 32-bit
i forgot what else you asked but it is a lap top, it runs alot of things very well, should i get rid of virtual dj cause there is no chance of it working with my computer? or just clean up my computer?
ram: 1662 mb
system : 32-bit
geposted Fri 02 Apr 10 @ 7:15 pm
oh 41.8 gb free of 222
geposted Fri 02 Apr 10 @ 7:21 pm
You may need to uninstall VirtualDJ software you have and install this version instead:
https://virtualdj.com/download/trial.html
All your PC settings seems ok, but what sound card are you using?
geposted Sat 03 Apr 10 @ 11:52 pm
