Forum: Old versions
Topic: Beat sync/lock two instances of virtual dj
Hey virtual dj people, i was wondering if any one had a solution to my problem, I use the multi instance skin to run two instances of virtual, here is the link to the skin https://virtualdj.com/addons/967/Multi-Instance_Skin_variations.html , In using this skin i am able to run two windows of virtual dj and in doing so have 4 decks. Now each deck will beat sync and lock to its twin deck in the same window like it normally does but won't beat sync to ether of the decks in the other window. So i am trying to find a way so the two "instances" or windows will communicate with each other and be able to beat match to the other decks in the other instance. If you have an idea or solution let me know thanks guys hope to hear from someone soon. =?
here is a video of my self doing a mix to show what the multi instance looks like in action if any one is confused what it is
http://www.youtube.com/watch?v=V2gx89vRK2E
geposted Sun 04 Apr 10 @ 10:52 pm
Just check in MULTI-INSTANCE TAB (Or Network Tab)
LOCAL SYNCHRONIZATION
That's all for multiinstance in the same computer. Just work in Windows.
Thanks Guys!! I will try it out today. =)
Yup it works, finally getting some progress with my mix, now we just need to talk about mixing video, but thats another forum, thanks again guys
tell next time,
peace =?
Anytime ;-)
