Forum: Old versions
Topic: BCD3000 as a midi controller only???
Hi,does anyone know how to connect the BCD3000 wiz Virtual dj to be use as a midi controller only???
I want to use it to control my effects and samples only???
Im using a pair of Stanton C324 and a DJX700 and Torq as soundcard.Thx
geposted Mon 05 Apr 10 @ 6:29 am
Hello,
You only need to install BCD-3000 drivers for you current OS, You can download it from Behringer site.
After doing that, download our trial version
https://virtualdj.com/download/trial.html
and install it your computer. BCD-3000 will work as midi controller just like that.
You can also use timecodes id you got a 4ins -4 outs sound card
Regards,
You would choose the sound card that you want to use in CONFIG -> Sound Setup
You don't have to use the one built into the BCD3000.
The BCD3000 will be detected as a MIDI controller automatically at start-up, providing that it is connected to your computer.
Oh is it??
So i dun need to use the BCD 3000 as the soundcard and it still can control my effects and samples automatically??
How to connect it to my mixer tho??
Simple. USB to BCD-3000, Sound card (whatever this is) and connect that sound card to your mixer or external audio device (like amp, or powered speakers, etc)
Regards,
thx so much mate
