Forum: Old versions
Topic: serial number prob
i have been using the dj console version of virtual dj and it was work just fine until i reinstalled it. after reinstalling i tried to execute virtual dj and it says i have an invalid serial key. can anyone help me please????
geposted Tue 24 May 05 @ 3:43 am
there is no serial number for the console version
probably you are trying to use a version that you are not supposed to use
please uninstall any "bad" versions, and reinstall the console version from the Hercules CD
if you still have problems, contact e-service, and we can fix so that console version will run again for you.
https://virtualdj.com/support/e-service/
probable after reinstall, you have only version 1.08 from the cd
register your hercules console in your profile and you will get access to download
update from 1.08 to 1.09 from this site.
Version 2.x is not an update for your hercules bundle !!!
Nice day to all
