Hi! (Sorry for my English, I speak it just a little)
I have installed Windows 7 on my PC 2 days ago.
Then I have installed Virtual DJ (pro v. 6.0.2), all seemed ok during the installation, but when I try to use the program, a form of error appears to me saying "Error in the ASIO Driver"
I have tried to download the newest one, but the error occours again...
Do you have any solution?
Thanks
Thanks
geposted Fri 09 Apr 10 @ 2:25 am
That doesn't necessarily mean there is an error in the driver it just might mean you don't have the right one selected under the config. menu.
geposted Fri 09 Apr 10 @ 6:19 pm
TeoneDJ,
Yes, it doesn't necessarily means you have any problem, it may simply mean that your DJ Console Rmx is in WDM mode, so VirtualDJ 6.0.2 Pro could not load the ASIO driver, and displayed this message. When you get this message
- check if DJ Console Rmx has switched in ASIO (set it in ASIO if it is still in WDM mode)
- and use VirtualDJ.
geposted Sat 10 Apr 10 @ 12:52 pm
