Forum: Old versions
Topic: not sure what happened?
Ok so lastnight I got bored (1st mistake) and downloaded this map,https://virtualdj.com/addons/8611/Ecler_NUO4_Def___Mapper.html. I tried it on my old laptop but couldnt get it to work. Well this time I did and now I cant get it to leave. Meaning, I dont like how the author mapped it out and I want to go back to my way but its not there. Before when I went to Mappers it would show, Keyboard or Generic. Now it only shows, Keyboard and ECLER NUO4. I just want my way to appear but it wont. When I go to, My Documents and open VDJ then Mappers I see my way and the ecler xml. But when I go to, Devices I only see the ECLER. If i delete the mapper and definition will my way (Generic mapper) appear again??
Hope this all make sense??
1 last thing, if i make changes will it save automaticly to the xml file for the Device and Mapper or do I have to do something funky??
Again I hope this all makes sense and THANKS for your help in advance!!
Huey
Also I noticed that there wasnt a defination xml for what I did only a mapper xml, how do I make a defination xml for what I mapped out?? Also anyone that uses an ECLER can I use Control lab4 for the making of the Def. file?? OK Im looseing myself now................
THANKS for your time
geposted Fri 09 Apr 10 @ 7:33 pm
Thanks for all your help, lol!! I have found the lost xml file!! Thank god cause I really didnt want to have to go through and map this thing out all again........
Make sure that you make a backup copy of it.
