when i open configue in this program i see a picture about sound card but i can't understand.
i want to set sound card for speaker and headphone but i don't sure my soundcard support it
i want to know about soundcard creative Live! 24-bit that can be work with my problem or other model to support it
thanks
thanks
geposted Tue 24 May 05 @ 9:39 am
Yes, almost any soundcard that has more than 2 speaker connections (your card is 4 channel or 5.1 channel - not sure)
in demo version this advanced configuration is not available (you cannot hear something else in the headphones and something other in the speakers) in full version it is enabled and you can setup
it in any way you like (for example deck 1 play in one output, deck 2 in other and samples in the third and use an external mixer)
geposted Tue 24 May 05 @ 12:42 pm
hi there! i have a 4.1 card.. how do i go about the connections as lopez453 mentioned in the above msg?
geposted Tue 24 May 05 @ 5:06 pm
go in options > sound cards and it is the third option from the top
and it is greyed out in your demo version :-(
in full version
you will choose your sondcard on the right
and in one output will be master
and the other jack in souncard will provide you with signal for headphone prelistening
if you want some crazy things as I mentioned in post above you should
use ADVANCED CONFIG (its the third from the bottom), click advanced
and you can asign your front left from your sondcard for one deck .... etc...
but it will not work in demo, at least you will see the config screen and consider if it is usefull for you,
in full version
geposted Tue 24 May 05 @ 5:40 pm
thankS for everyone for answer it to me..
geposted Thu 26 May 05 @ 10:33 am
To lopez453
Thanks for answer me but i can't complete..
1. i can't set my soundcard for output when i connect headphone and speaker
2. i want to know how method to set two or three soundcard on computer
3.when i go to configue for set soundcard i chose the pigture that one soundcard and connect with headphone and speaker but i can't here soud togeter.
please help me.....
and i want to contact you by e-mail. my mail is --@--.--.
i live in bangkok,Thailand
Thanks..
Toon........
Moderated by Lady Cameron
Sorry toonytoony2004 no email address is allowed from a demo user
please help me.....
Thanks..
Toon........
geposted Mon 30 May 05 @ 9:13 am
when you click on my name you will se a blog and there you will find my e-mail address.
If you have more soundcard you can use them only in full version, not in demo...
It works for my built in notebook soundcard and external USB soundcard.
geposted Mon 30 May 05 @ 11:05 am
Please..
Now i use soundcard creative audigy 2 Value 7.1 but i can't set for complete
when i conect headphone and speaker togeter i can here speaker only or headphone only
I have 2 soundcard but it"s different of model.Can i set follow same this picture and how?
I want to conect with mixer for One or two soundcard.Can i set follow same this picture and how?
I don"t sure with my program that full version or demo.
Thanks for ask this Question and hope for your answer
..sorry please your mail is --@--.--......right?
geposted Tue 31 May 05 @ 6:54 am
you are not able to do this in demo...
in full version all is ok.
I fyou have purchased full version, please fill your licence in your profile
geposted Tue 31 May 05 @ 11:57 am
