Forum: Old versions
Topic: Solved! Technics & VDJ
Alright!
After posting a thread about weak signal using Technics, I figured it out.
Here is the original thread:
https://virtualdj.com/forums/126752/PC_Version_Technical_Support/Weak_Signal_-Time_coded_vinyl.html
Answer to the Solution:
If you are using Turntables with Phono, YOU MUST USE A PHONO PRE-AMP TO YOUR SOUND CARD FIRST!!!
The Phono RIAA filter that VDJ comes with is garbage. It gives a weak signal, which isn't good at all for mixing/scratching. After using a phono pre-amp, I've two PERFECT green circles. So yes, you don't need to buy new CDJ's, or a Hercules RMX console...fuck that...use vinyl, use your old Technics!
Message me if you have issues!
I've sucessfully used a U46XL on Windows 7 32-bit using old Technics MK-5's with Serato Vinyl. It's possible, dont give up on turntables.
geposted Sat 10 Apr 10 @ 2:28 pm
what version of vdj are you using?
@dj d-oh, so which 1 are you using and are you going, Turntable, Phono Pre-Amp, Soundcard then Mixer?
Yeah, that's exactly it.
Turntable Phono&RCA, Phono Preamp Input, Phono Preamp output, Soundcard Line/RCA input, soundcard output to Mixer.
I'm using VDJ 6.02
