Did you copy the m3u file to the 'playlist' folder in the VDJ directory?
cstoll
cstoll
geposted Tue 24 May 05 @ 2:28 pm
you cannot drag a playlist and drop it to a deck ;-(
I think you have to drop the m3u playlist into you vdj playlist on the right side of the browser
or you must click thru explorer and after double click the playlist expands and looks like a folder of files
geposted Tue 24 May 05 @ 2:49 pm
correct lopez453!
and you can use playlist wherever at your disk is.
Dj Nikki
Dj Nikki
geposted Tue 24 May 05 @ 2:52 pm
Here is a link to another thread where someone had the same problem.
https://virtualdj.com/forum/display.html?topic=12271
Their solution was putting the playlist in VDJ's playlist folder. This maynot be the absolute solution, but worth a try?
cstoll
cstoll
geposted Tue 24 May 05 @ 4:10 pm
yeah.. i did all that.. i meant after i load (or double click the playlist file) and then, in the playlist window, the file which i dragged to a desk refuses to play...thanks...but i still need some help ;(
geposted Tue 24 May 05 @ 4:34 pm
look into file with some texteditor (notepad.exe)
and compare your playlist with those from virtual dj
maybe there is relative path in the playlist only....
and vdj could not figure out where are your files located exactly
geposted Tue 24 May 05 @ 4:47 pm
yes i did that just now..there seems to be a major difference in the playlists which i cant correct cos its too much to understand....but the weird part is that one song played from my m3u playlist (only the first song) the rest dont even respond... that is i cant even right click and listen nor can i even analyse them...but when i open them thru the browser...they play perfectly.... please help...i need to use the m3u playlists... cos all my files are in different folders...thanks
geposted Tue 24 May 05 @ 4:57 pm
if there are lines with comments
beginning with #
maybe you have to delete them
and see if you can play the other files
begin with few lines and see for yourself
beginning with #
geposted Tue 24 May 05 @ 5:35 pm
By the way, using a legal demo or full version is a good point to start, your 2.05 cracked version contains a lot of bug we can solve for you...
geposted Tue 24 May 05 @ 6:03 pm
