is it possible to run pioneer cdj 100s through my hercules rmx and mix using vdj pro? :) my setup is two pioneer cdj 100s hercules rmx and im getting kam soundpack2 this week idealy i want to run the whole setup through vdj im new to this setup so hopefully people can help me set it up all correctly thanks :)
geposted Mon 12 Apr 10 @ 10:55 am
Hello,
You can use Pioneer CDJ-1000 connected to LINE IN in your RMX (check your RMX switch selector is in LINE IN). You may need CD timecodes to each CDJ-1000 to work with VirtualDJ using timecode control.
https://virtualdj.com/wiki/TimeCode%20Config.html
Also you may check in here:
https://virtualdj.com/wiki/Hercules.html
https://virtualdj.com/homepage/xonor/blogs/3288/VIRTUAL_DJ___RMX___TCVS_%28Mac_Version%29_TCCDs_too.html
(last one works for PC configuration too)
geposted Mon 12 Apr 10 @ 11:13 am
Hello smoothy,
I suppose you want to play audio CDs on CDJ100S but not time code CDs since, as you have no scratch mode on CDJ100s, your scratch control on CDJ100S jog dial will not be good.
You can play audio CDs on CDJ100S players and connect the player outputs on Rmx audio inputs (set in line mode), but, in case it saturates, you may have to reduce CDJ100S output volume, with inline volume control as
Rockford Fosgate RCA level control
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=150352227056
http://www.tmwoffroad.com/product.sc;jsessionid=D497F2741DD09F236AB13ACB2B670675.qscstrfrnt02?productId=313&categoryId=42
Vibe BC10
http://www.vibeaudio.co.uk/shop/index.php?act=viewProd&productId=94
http://www.caraudiodirect.co.uk/vibe-bc10-controller.html
or equivalent
http://www.amazon.com/PAC-Remote-Amplifier-Level-Controller/dp/B0002J226O/ref=pd_cp_e_0
CDJ100S output level is set at +8dBu, while DJ Console Rmx inputs are made for +4dBu inputs, so it may saturate.
I am not sure CDJ100S players are the best solution for mixing your audio CDs:
- you can control audio CDs in VirtualDJ,
- so I suppose you will get a better control on your audio CDs in playing the audio CDs on your computer CD/DVD player, mix the track in VirtualDJ, and control them on DJ Console Rmx jog wheels.
Vibe BC10
or equivalent
geposted Tue 13 Apr 10 @ 5:09 am
thank you for your replies :D i have set up the pioneers to work with virtual dj but need some more help please will i be able to control the cdjs looping etc.... through the vdj interface? when i have cdjs playing discs the vdj platers arent moving and only cross fading mids high and lows seem to be working do i need to change skin too pioneer one? and how easy is it to all do ? thanks :D
geposted Wed 14 Apr 10 @ 12:25 pm
