VU METERS should show the level of the mp3 not the volume level. If I want to know what the volume level is, I can look at the slider! the VU METERS should move to the music beat
geposted Sun 17 Aug 03 @ 1:43 am
You have asked this before and GOT an answer From Dams:-
"If you want real vu meters, just edit the xml file of the skin, and replace source="volume" by source="beat" in the sliders related to that."
http://www.virtualdj.com/forum/display.html?topic=1100
geposted Sun 17 Aug 03 @ 2:17 am
sorry I missed that
geposted Sun 17 Aug 03 @ 2:25 am
how do you edit XML? I am not a web developer
you dont need to be :)
just open up the required xml in a program like notepad and find the appropriate line edit it and save it and your away :)
geposted Sun 17 Aug 03 @ 2:38 am
ok thank you.
geposted Sun 17 Aug 03 @ 2:42 am
I edited the skin file and found 2-3 places that needed to be changed. It worked, so much better.
However, I noticed that that the whole GUI seems much slower than before. I guess the VU meters take a lot of processor power and maybe that is why the advanced skin had it set off?
I am running an AMD Athlon XP 2400+ with 512MB Ram Windows 2000
geposted Sun 17 Aug 03 @ 2:03 pm
Ouch! I have to revert back. The GUI slowed down too much and the record scratch doesn't work like before. Can anbyone else confirm this?
I really like the Vu meters on like this this but if it affects the audio, it is not worth it.
geposted Sun 17 Aug 03 @ 2:21 pm
Please disregard my last post. I removed Virtual DJ, re-installed and still have GUI slowdown. Something else must be wrong with my system and is not related to VU meter tweak.
"was working last night"
geposted Sun 17 Aug 03 @ 2:41 pm
to: WirelessDJ,
I was thinking to ask you if you notice any slow down
in Virtual Dj performance, after you scanned your 22,000
tracks resulting a 6.5 MB database (in the ''analyze'' topic)
I see now you have a problem, but you dont know what it is.
Just thinking, maybe this is the problem or maybe not.
Please check it and let me know.
Just move the internal database file to another folder,
and Vdj will create a new one -empty- when start again.
geposted Sun 17 Aug 03 @ 8:50 pm
Yes it does slow down for me. When I first open virtual DJ it always goes to the two demo songs. I dont know how to make it remember the last folder it was in.
then I click on my C: drive on m mp3 folder. My tracks are broken up into many sub folders.
c:\mp3
c:\mp3
geposted Mon 18 Aug 03 @ 3:06 am
ahh it me off...
c: mp3 (this is top layer)
c: jazz
c: 1980s
c: 1990s
c: trance
c: drops
c: disco
etc etc etc
I havent finished counting so the file will be much larger than 6.5mb.
It did slow down though, it takes 12 seconds to open the top layer folder with 22000 tracks total.
c: jazz
c: 1980s
c: 1990s
c: trance
c: drops
c: disco
etc etc etc
geposted Mon 18 Aug 03 @ 3:10 am
It is normal to have a slow response when you browse,
folders - subfolders, because Virtual dj have a direct access.
Like an internal windows explorer
(Unlike other programs)
The file mp3database.txt is used for the search function
and is much quicker, while internal database file store the
cue/bpm infos
I like this feature, because you can make changes, move files
outside the program, without having to update the recordcase
everytime (Pcdj).
But try to see if the ''slow'' browser affect the performance when you mix, using eq, effects etc.
Also try with an empty internal database file.
To set your mp3 directory as default, select it and press
the red button with the folder icon.
cue/bpm infos
everytime (Pcdj).
geposted Mon 18 Aug 03 @ 6:06 am
is there a way to specify in the vu meters xml file the right and the left channel (to be in stereo)?
geposted Wed 20 Aug 03 @ 6:35 pm
YES kabensa ... good ideea :)
I need too
please answer me :)
thx so much
PAUL
I need too
please answer me :)
thx so much
PAUL
geposted Mon 25 Aug 03 @ 11:30 am
