Hello DJerz
When i go to the drop down menu bar at download > Plugins > Sound Effects
I can not download anything there it. Anyone know how to fix
this? that would be great
"Your current licenses do not allow you to download Effects"
(thats what it says when i try to download some).
geposted Sat 17 Apr 10 @ 10:33 pm
Plugins are only available to be downloaded by registered licensed users. If you own VDJ (or Cue) then register your serial number in your profile and you will gain access immediately.
If you are using a trial, a pirate version or a version purchased from elsewhere then I am afraid you are out of luck.
geposted Sat 17 Apr 10 @ 10:47 pm
