i have a hercules RMX and i've seen this done with a VCI-300.
i was wondering if there is anyway to control effects on my RMX (such as the flanger). now i'm a total noob with macros and such and don't even know if this can be done. since i don't ever use the "load deck A" and "load deck B" buttons on the RMX, is there a way to set a macro so that when i press that button, say "load deck A", that the effect will start on deck A.. but THEN control the effect with BOTH pitch sliders as if they were both the knobs that you see in virtualdj to control the effect?
geposted Mon 19 Apr 10 @ 2:57 pm
read this. I was having the same problem, https://virtualdj.com/forums/127184/Hardware_Technical_Support/Activating_Macros_with_a_fader__.html
For your effects try this for deck 1, deck 1 effect slider 1, deck 1 effect slider 2.
Hope this helps
Huey
P.S. I think this topic belongs in the hardware forum, lol.
Hope this helps
Huey
geposted Mon 19 Apr 10 @ 4:49 pm
yea that helps a little.. i'm just lost in the sauce when it comes to coding this stuff.. haha
geposted Mon 19 Apr 10 @ 4:53 pm
