Forum: Old versions
Topic: Please help me to change skins in VDJ 5.2.2
Hi,
I have the hercules steel console and VDJ 5.2.2, I can't see where to change skins!
I got the product on CD with a console and got a serial key which I have logged in.
Please can someone provide me with a step-by-step guide on how to change skins.
Thanks in advance.
geposted Mon 19 Apr 10 @ 5:11 pm
Sorry, the software that you received FREE with your DJ Console is a limited edition of the software and does not allow custom skins to be used or the program configuration options to be changed (Except during the 20 day trial of Pro.)
To be able to use custom skins and much, much more you will need to upgrade to VirtualDJ Professional: https://virtualdj.com/buy/
Your Steel DJ Console version entitles you to a considerable discount off the cost of upgrading. To receive this, please go to the above page and enter your DJ Console software serial number in the box provided at the bottom of the page.
Thanks for your advice.
Much appreciated.
