I have a pair of Denon 3700's and use them through midi and would like to be able to, easily, use my laptop's internal soundcard as a 3rd channel for the sampler. I am by no means a software designer but wouldn't it just take a driver like the Asio driver to be re-written to include the PC's sound card into the set up?
Left deck 3700 1, right deck 3700 2 and 3rd channel PC sound for sampler etc...
I know I can use an external sound card BUT I am trying to avoid adding yet another piece of hardware and using up another USB port.
Is this a possibility?
geposted Tue 20 Apr 10 @ 1:06 am
It's nowhere near as simple as you make it out to be. You can't just rewrite an ASIO driver unless you wrote it in the first place since 99% of them are closed source. Each ASIO driver for each card is also different!
If you're using ASIO in VDJ you are limited to a single card anyway. The only way around this is to use an emulation layer - such as ASIO4ALL - to present a virtual card to VDJ with the relevant number of inputs and outputs configured to relevant physical outputs.
Be aware that using a layer like this means you will have to configure your performance settings to accomodate all cards - including the generally crappy performing onboard sound card.
geposted Tue 20 Apr 10 @ 4:47 am
I certainly didn't mean to make it sound as if it were "easy", I don't know anything about writing code. Do you know, does anybody have a driver that does make use of the l/r channels to decks and you can use a 3rd for the sampler on the onboard sound? I am not concerned that the laptop sound isn't a great fidelity card, I would use it for drops and bumpers etc...
geposted Tue 20 Apr 10 @ 9:52 am
ASIO4ALL.
It's not just fidelity though - you may have to increase your latency etc...
geposted Tue 20 Apr 10 @ 10:07 am
Thanks SBDJ but what does all of that mean? Sorry I am clueless when it comes to custom drivers etc...
Thanks.
Thanks.
geposted Wed 21 Apr 10 @ 12:19 am
There is an application called ASIO4ALL. You can use it to configure a virtual soundcard from your real soundcards ;)
geposted Wed 21 Apr 10 @ 5:31 am
But I gather from your earlier reply it's not a great sounding driver?
geposted Wed 21 Apr 10 @ 1:34 pm
ASIO4ALL sounds fine. The problem comes in that if you are using multiple soundcards in ASIO4ALL, then you have to set your latency settings suitably - and that may well mean setting latency higher than normal.
geposted Wed 21 Apr 10 @ 3:06 pm
Thanks Scott. So, should I move to that driver will I have problems with my Denon 3700's?
I run 2 connected via USB to a Dell Inspiron 1505 Core 2 Duo 1.83gHz with 2GB of ram. I have only been using them for a few months and still don't have them operating at peak performance yet so will this further slow my progress?
geposted Thu 22 Apr 10 @ 12:19 am
maybe this idea could be added to the soundcard config page in VDJ??
So you can set your card for the decks, then have a seperate setting for sampler...
geposted Sun 25 Apr 10 @ 10:54 am
