hey I'm here to help those that downloaded the demo of this and don't have the mapping for the ion dj discovery. Here's my custom mapping, you may also add to this as it would make this mapping more helpful for other. I'm using virtual dj 5.2.1. I find that 6.0.2 doesn't match this as well
left hand side
cue button = cue on deck 1
sync = sync on deck 1
volume knob = gain, absolute, on deck 1
bass knob = bass, absolute, on deck 1
treble knob = high, absolute, on deck 1
play = play_pause on deck 1
pitch -% = pitch, value -16, on deck 1
pitch +% = pitch, value +16, on deck 1
while moving the platter = scratch, encoder, +1=1, -1=127, increments 100, on deck 1
after tapping platter = hold, momentarily, value = 1, on deck 1
on right hand side
cue button = cue on deck 2
sync = sync on deck 2
volume knob = gain, absolute, on deck 2
bass knob = bass, absolute, on deck 2
treble knob = high, absolute, on deck 2
play = play_pause on deck 2
pitch -% = pitch, value -16, on deck 2
pitch +% = pitch, value +16, on deck 2
while moving the platter = scratch, encoder, +1=1, -1=127, increments 100, on deck 2
after tapping platter = hold, momentarily, value = 1, on deck 2
mixer
master volume knob = master volume, relative scale 100%
crossfader = knob, relative scale 100%, invert
left hand side
on right hand side
mixer
geposted Fri 23 Apr 10 @ 12:16 am
If you down load the latest trial you will find it is fully supported properly.
geposted Fri 23 Apr 10 @ 5:15 am
