Does anyone know how to reset the database in VDJ?
geposted Fri 27 May 05 @ 1:24 am
go to your c:programfiles/virtualdj folder
look for the virtual dj database.xml and the vdj database.txt delete both files tada.....
geposted Fri 27 May 05 @ 1:51 am
Thanks Cyder!
geposted Fri 27 May 05 @ 3:27 am
Your welcome Rob
Now when you get your database the way you want it. Make sure you back it up the text file isn't important with backup just the xml. This is where your cues and bpms and comments are stored in the xml file.
geposted Fri 27 May 05 @ 3:44 am
I'm still confused.
I recently upgraded to 3.4 but now all my comments are missing from the old version of VDJ that I was using.
To fix this, do I have to go to my VDJ folder in the 'old' version, and copy the"VirtualDJ Database.xml" into the 'new' version?
Anything else I need to do?
Thanks in advance.
Thanks in advance.
geposted Fri 19 May 06 @ 4:38 pm
You only need to replace the new VirtualDJ Database.xml with the old one that you were using before the new install.
geposted Fri 19 May 06 @ 5:30 pm
